Had to replace my battery (2016 Octavia VRS)
What coding do I need to do in what modules.
Did a search but they all come up quoting other post but no working links.
i believe there r four channels under the [CAN Gateway 19], [Adaptions-10] using VCDS.
(1)-Battery adaptation-Rated battery capacity
(2)-Battery adaptation-Battery technology
(3)-Battery adaptation-Battery manufacturer
(4)-Battery adaptation-Battery Serial Number
There are videos on Youtube (done by Ross Tech) on what you need to do.
Battery Replacement - Ross-Tech Wiki
Fast forward to about the 5 min mark https://youtu.be/36OB96OtUsE
Thanks guys. That should get me sorted. I just got the factory Varta replacement. Mine had a MOLL branded EFB batt. Seems I got the Chinese version from the factory. Only lastEd 3 years and I don’t use stop/start
