11 Attachment(s)
Mk2 2dr Project Car (now VR6 swap)
Start date: 16/02/2019
Gday everyone,
Decided to get my first post in of the project car. I'm from Tasmania and seems mk2's are very few down here now.
Attachment 47673Attachment 47668
Bought the car completely stripped back and everything came with it except the engine. Also got a parts car, it looks pretty sad haha (no struts in it). Keeping in mind all the suspension parts and gearbox and drive shafts etc. were pretty well toast. This is my first ever project car so I realised I had a lot of learning to do.
Attachment 47675Attachment 47665
First start was getting engine bay cleaned up. Took a lot longer than I thought, only getting areas about 300x300mm completed in like 5 hours. Started with wire brush, to sand paper, to little wire wheels, to the large wire wheels on a grinder which helped a lot. About 2 months later finally got it done. Had some rust issues under battery which seems common and so cut it out and patched it. Will neaten that up for when body goes in for spray. However, all metal has been deoxidised and converted and then primed over so no rust should continue.
Attachment 47670Attachment 47667
Rolled the car over onto its side as, unfortunately, I do not have a rotisserie, took off all suspension and brakes and made note of what parts need to be ordered. I bought a full poly-urethane bushing kit and pretty much new discs, pads, front calipers, tie rods, rubber boots, wheel bearings, ball joints. A lot really. Thanks to VW heritage for that, pretty cheap stuff.
Attachment 47666
Current stage I am at now is shaving underside. Heating up the deadener and scraping it off. Found rust on a jacking point so did some cutting and welded back in place. Not fussed how it looks, as long as it is strong. I have also been respraying control arms and front and rear subframe with some rust proof enamel to make them look like new. Have resprayed steering rack, not gonna bother with putting in a power steering one (I have one on my parts car), too many things to replace. And plus more stuff in the engine bay.
Attachment 47672Attachment 47669Attachment 47671Attachment 47674
This is where its at. I am a uni student and the mk2 is located couple hours away from me as I have no where to put it at home. So that limits the progress. Enjoy! And any Tassie enthusiasts hit me up, I drive a silver mk4 GTI, on black BBS RC 324's.
Cheers,
Thomas
