Long time coming (and expected to take a long time to finish!) but it's time to switch the "pipes and slippers" Bora 4motion into a ball tearing Bora R32.
So I picked up this beast about a year ago after my previous 4motion was written off. One owner, very clean besides some slotted rotors and the Evolo alloys she's stock.
Attachment 33446
In stock:
Oettinger body kit
Forge R32 CAI
R32 brushed aluminium trim
Bora 4motion (donor vehicle, long story)
BBE 3'' exhaust with Magnaflow R32 style muffler and twin pipes
Yet to get:
R32 donor
Coilovers
Suspension refresh kit
Wheels (undecided yet but leaning towards some Oettinger RZ's)
Dieselgeek shorter shifter
Time, tools and knowledge to do the job!
So the first thing I thought I'd get onto was the horrible woodgrain trim. I managed to source some brushed aluminium trim from the UK out of a 5door GTI 20th anniversary.
Attachment 33434
Here's a tip for anyone looking to remove a MK4 stereo without the removal tool. Cut up an old ATM card, works perfectly!
Attachment 33435
With that out of the way it was time to strip the lower end of the dash to remove the radio cage.
Attachment 33436
For anyone doing a similar swap the radio cage side trims can be removed by doing the following.
Attachment 33438
There is 4 pins on the backside of the trim. 3 pins have lip which clip into small claw on the radio cage. The pin without the lip locks in behind a tab. You can try bending the tab but I found it easier to insert a small screwdriver at the back of the radio cage and push the pin up to clear the tab. Once clear gently slide the side trim towards the bottom of the cage.
Attachment 33437
Other than that everything just clips straight in.
Before:
Attachment 33439
After:
Attachment 33441
Now onto the doors. Started at the rear passenger door, removed the door card and changed the handle / speaker assembly complete, unfortunately I busted one of the plastic clips on the back doing this.
So rather than risking breaking any more clips I found to change the inner door handles only you can do the following.
1. Remove the door card
2. Unhook the cable attached to the handle.
3. Extend the handle as far back as it will go
4. Pull it downwards and the top of the handle will pop out, then pull it up and the bottom will come out. Then just wiggle the spring out. Installation is reverse.
Attachment 33442
Attachment 33443
The inner door grabs simply pop on and off with a flat blade which is inserted at the lower edge.
Before:
Attachment 33444
After:
Attachment 33445
