Links and Index of VCDS Tweaks
Hi guys,
Thought I'd start a thread on any VCDS tweaks people have had success with. I assume most of the ones that work for the Mk7 Golf would also work but will be great to know which ones actually do work! Any screenshots, pictures, videos associated with the tweaks would be great! I'll let you guys know which ones work when I get my car and get around to borrowing/buying a cable!
These are the ones I'm keen to do on my Tiguan when it arrives:
1) Deactivation of auto stop/start
2) Memory retention of seat heater setting
3) Deactivation of seat belt reminder
4) Activation of Volkswagen Traffic Message Channel
5) Driving school mode
6) Air-conditioning recirculation memory setting
BTW, courtesy of DV52, here is the Mk7 Golf VCDS reference thread: MkVII VCDS Tweak - Reference thread
He has uploaded a full BCM database, thanks to VWVY for providing his car: Mk2 Tiguan VCDS Tweaks - Page 8
CONFIRMED working VCDS tweaks:
Activation of Volkswagen Traffic Message Channel: Mk7 Golf TSI & TDI - Observations and Questions - Page 56
Deactivation of auto stop/start (courtesy DV52 and VYWY - post #94, exactly the same way as Mk Golf 7)
CONFIRMED working OBD11 tweaks:
Some cosmetic changes to AID and central MFD(courtesy NZ_GolfR): Mk2 Tiguan VCDS Tweaks - Page 26 & Mk2 Tiguan VCDS Tweaks - Page 10 & Mk2 Tiguan VCDS Tweaks
More tweaks: LED lights in door mirrors, DRL adjustments, refuel quanity, fan speed indicator when in auto, changing comfort blink amount, guage sweep, beep when locking/unlocking car (cheers bestyjny): http://www.vwwatercooled.com.au/foru...ml#post1222463
Screen nag deactivation (cheers VWVY): http://www.vwwatercooled.com.au/foru...ml#post1223437
Active Lane Guidance intervention settings (cheers Fried_noodles)http://www.vwwatercooled.com.au/foru...ml#post1224141
Light Assist (NZ_GolfR): http://www.vwwatercooled.com.au/foru...ml#post1226372
TMC, DRL option in Head Unit, Auto window closing, Dynamic Road Sign display(Cheers hoola): A guide to enable EU specific features for AU Spec Tiguans
Easy Entry/Easy Exit seat function (NZ_GolfR): http://www.vwwatercooled.com.au/forums/f238/mk2-tiguan-vcds-tweaks-116815-18.html#post1239603
360* Camera for Discover Media infotainment systems (Hugo_nz): http://www.vwwatercooled.com.au/foru...ml#post1239530
Always on rear tail light DRLs (NZ_GolfR): Mk2 Tiguan VCDS Tweaks
Air-conditioning recirculation memory setting: http://www.vwwatercooled.com.au/foru...ml#post1242006
3rd rear brake light activation, Door mirror LED on with folding of mirrors, cornering fog light speed sensitivity: http://www.vwwatercooled.com.au/foru...ml#post1243852
Haldex AWD system adjustment: http://www.vwwatercooled.com.au/foru...ml#post1249239
Key Fob works when outside the car even whilst engine running (allows you to get the car running to precondition the interior and walk away with a locked vehicle): http://www.vwwatercooled.com.au/foru...ml#post1256693
Driving School Mode: http://www.vwwatercooled.com.au/foru...ml#post1263040
Deactivate the Prevention of cars overtaking on the Right (Tigger73): http://www.vwwatercooled.com.au/foru...ml#post1281355
- This tweak is helpful on the freeway when you are not in the right lane and approach a slower car driving in the right lane.
Usually the car slows to the other cars speed (annoying if the car in the right lane travelling at 100km/hr in a 110km/hr zone) and does not proceed past them.
Deactivating this setting allows you to continue at your predetermined cruise control speed and pass the car in the right hand lane.
Reduce throttle tip-in delay and improve responsiveness:
http://www.vwwatercooled.com.au/foru...ml#post1290159
Hillbilly's list of things tweaks that have worked: https://drive.google.com/file/d/1XT_...TPRJFZyeG/view
Additional things in that list include:
- Puddles in mirrors when reversing
- Enable change navigation whilst car is moving
- Adjust speed in dash to be correct for cars with 20" wheels
- Dynamic Light Assist (courtesy of Phonebooth) - I have tried this and unfortunately does not work for me
AutoInstruct's OBD11/VCDS tweaks:
https://www.autoinstruct.com.au/manu...n-vcds-tweaks/
Stemei.de coding: https://www.stemei.de/pages/coding/vw-tiguan-ii-ad.php
Record of NZ_GolfR's tweaks:
https://oncall-my.sharepoint.com/per...ding%20Changes
Thanks veew. Really keen to know if number 4 works!
Agreed please fully document these and more.
An aside question. Would any of these changes have a negative impact on our VW warrantee?
Sent from my SM-G930F using Tapatalk
Thank you tigger73 for the update.
Hi boys (and girls?). I don't normally post on the Tiggy thread (I'm mostly on the Golf mk7 forum), but as you will be aware, the new Tiggy and the mk7 share the same MQB build platform. This suggests that VCDS tweaks for the mk7 might be applicable to the new Tiggy (perhaps?)
So, on this assumption, there are at least 3 x different ways of neutralising SS on a mk7 (that I'm aware-of - there could be more)
- Coding change to the Byte3, Bit 2-3 on the CAN Gateway module @ address hex19 - The factory value for Bits 2-3 are hex04 for SS active (i.e. Bit 2=1, Bit 3=0). To disable SS, change this to hex08 (i.e. Bit 2=0 ,Bit 3=1)
- The "Temperature method"
- The "Voltage method"
Because not much is known about the new Tiggy's CAN network, I wouldn't suggest tinkering with the CAN Gateway code-string just yet - so option I is probably not viable at this time.
But Options II and III are low risk because they just involve changes to Adaptation channels - which can be simply reversed if needed.
So - here's the question: has any owner of the new Tiggy made an adaptation channel map of the control modules in their car and in particular can anyone post-up the admap for the CAN Gateway?This will show us what channel identifiers are in the module.
PS: If you haven't made a full database of you car, then I seriously suggest that you do so. One of the distinctive features of MQB platform vehicles is their reliance on adaptation channels. Here's a sobering statistic - my mk7 has in excess of 5,500 adaption channels in its CAN network and just under 40% of these are in the BCM. And my car has only 14 x control modules - so it's not a highly optioned vehicle. An accurate database of adaptation channel settings (in the car's virgin state- before any changes are made) can be very valuable when tweaks go "pear-shape". Make a full set of admaps, you won't regret it!!!!
