Hey guys, I'm having issues with my 09 Octavia VRS petrol and was hoping someone else has had a similar issue before. I've had code P0087 come up when I scan the car which is "Fuel Rail/System Pressure Too Low". Looking up the interwebz says that there can be multiple causes including high pressure fuel pump, fuel pressure sensor, fuel filter. So far I have replaced the fuel filter and the high pressure fuel sensor. Before I replace the high pressure fuel pump I was hoping someone could confirm I am going in the right direction.
Basically the car has gone into limp mode with multiple cylinder misfires. There is a ton of smoke coming out of the exhaust from unburnt fuel, infact fuel is dripping out from all of the exhaust joints, there is that much unburnt fuel going through the system. The spark plugs are all new. Does the high pressure fuel pump look like the next step. Has anyone had something similar happen? Thanks in advance.
