Creaking/squeaking doors and door seals
Upon my daily drive to get coffee, as I went up the drive way to the coffee shop (at an angle) I heard all the doors creak quite loudly!!
And from there on I could hear it creak on every road surface that was not level.
I spent the remainder of the day in a paranoid state thinking the car was going to fall apart after just 5000km.
Was going to book it into the dealership to demand it be fixed ASAP but I thought I should see if any one else has this problem.
I found out that yes others do have it and it is a simple fix.
Here is the link to another forum
Creaking doors? Mystery solved - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
And this is the fix
1z Einszett car care products - Gummi plege stick 150ml
So I have ordered this and will report back when it arrives
In the mean time if any one else has/had or knows of this problem please feel free to let me know :-)
Alex
Door allignment and banging/rubbing on Mk7
I have a rear door on my GTI that makes a LOT of noise. Rubbing seals and "banging" for want of a better term.
I have adjusted the door striker and reduced the problem however note the door is not aligned as well as the other side which is silent.
In fact if I use one finger and push on the glass or the vertical bar between the two panes the door "bangs" against the body.
It feels like that support on the door is moving more or looser than the opposing side.
I am seeking some advice on the following:
1. is that support between the panes possibly loose?
2. I loosened the door hinge bolts however cannot get the hinges to move. Are they bonded by paint or an internal bolt as well??
I don't want to go down the path of plastic tubing at this time and will have the car to the dealer on the 17th to correct tint and look at the door. Last time they just lubricated it so I'm hoping to have some targeted info to get a better result :).
How widespread is this problem on the Mk7? I saw a lot of threads on older models trying to find answers....
