Need help with tyre size for Mk4
Hey guys,
I'm currently running 18x9 et20 (after 15mm spacer) with 225/40/18 tyres.
The front is fine, but when i put my rear spacers on my tyres and fenders start making love to each other.
Here is what it looks like with the spacers fitted, do you guys think 215/40 will be fine to run or would i be better off going with 205/40?
http://www.vwwatercooled.com.au/foru...paze9y4e-1.jpg
Re: Need help with tyre size for Mk4
I am running them on the front to clear my coilovers, so with the back ones off i end up with my front wheels sticking out 15mm more than my rear, which looks a bit silly IMO
Quote:
Originally Posted by
dylan8
I'd try and find a 'narrow' 215/40.
If you lower the front more you wont require such big spacers in the back to match the poke
What would you say a narrow 215 would be? I was gonna go with pirelli pzero but i read that they have pretty thick walls, i'm not sure if the front can go much lower to be honest, i guess i could go smaller tyres all round and lower both front and rear a little more?
Thank you man! i've always wondered how guys run higher offsets in the rear but make it look more aggressive than the front.
I'll see what i can do with that and hopefully fix it up this week
Decided to go with camber shims in the end. Should be done by the weekend i hope :)
dylan8
How much you go?
Need your car in the mk4 wheel library too!
I'll most likely end up going -1 degree, i've got two extra -1/2 degree shims incase it does end up needing more tho.
I'll get the specs on there as soon as this is done :)
kdog
that fitment though!!!!!! :O
Thanks mate :), should look a bit better once i get it all right
