VCDS Scan, butt load of problems, help?
Having some malfunctions come up, could anyone help me diagnose? :)
I have been to VW and am getting a new cam sensor, (my car barely starts), but the other stuff??
Code:
Chassis Type: 1K0
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 018 FC HW: 03G 906 018 FC
Component: R4 2.0l PPD1.2 G 1879
Revision: --H52--- Serial number: VWX7Z0H23NV8RC
Coding: 0000078
Shop #: WSC 00046 412 00000
VCID: 6BD1C39F3315
2 Faults Found:
012295 - Camshaft Position Sensor (G40): No Signal
P3007 - 006 - Short to Plus - Intermittent
000833 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 006 - Short to Plus - Intermittent
Readiness: N/A
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 050 C HW: 02E 927 770 AE
Component: GSG DSG 082 1402
Revision: 09908020 Serial number: 00000803150152
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 122FBE7B74FF
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
VCID: 73E1DBFF6B25
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6DD5CD870D01
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000008259901
Coding: E5898F2700041500471400001400000000087F075C000100000000000000
VCID: 71EDD1F71139
Part No: 1K2 955 119 E
Component: Wischer 130508 020 0501
Coding: 00049109
Shop #: WSC 00046
Part No: 1K0 955 559 AF
Component: RLS 090508 046 0204
Coding: 00208933
Shop #: WSC 00046
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 1P AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1RW03Q
Coding: 0012624
VCID: 3D753DC71DE1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0012122
VCID: 78FBECD37243
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 874 B HW: 1K0 920 874 B
Component: KOMBIINSTRUMENT VDD 2216
Revision: V0002000 Serial number: VWX7Z0H23NV8RC
Coding: 0003103
Shop #: WSC 30067 959 86331
VCID: 2C530083F69B
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K083018194
Coding: ED807F064006120003
VCID: 306B14F3DAB3
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 2216
Shop #: WSC 30079 959 15689
VCID: 2C530083F69B
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669863893
Coding: 010000
VCID: 285BFC93E263
1 Fault Found:
03138 - Input AUX IN
009 - Open or Short to Ground
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 C
Component: RNS-MID H50 2760
Revision: AB001001 Serial number: VWZ6Z7Z0000000
Coding: 0E0004000400002200
ASAM Dataset: ------------------------- ------
VCID: 2E570A8BC087
2 Faults Found:
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
01042 - Control Module; Not Coded
000 - -
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1210
Coding: 0000692
VCID: 387B2CD332C3
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 366722EB38D7
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 999002005103087F2D04840560085F0380FC00
VCID: 83010B3FBB85
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: 397D29D709C9
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2E570A8BC087
2 Faults Found:
000 - -
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 00046 412 1012544
VCID: 387B2CD332C3
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
VCID: 397D29D709C9
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660093958
Coding: 0A00000000010100
ASAM Dataset: EV_UHVNA A01015
ROD: N/A
VCID: 356525E725D1
No ASAM data for: "EV_UHVNA" (VW35)
3 Faults Found:
9455633 - ROD - Unknown Error Code
9458195 - ROD - Unknown Error Code
13636352 - ROD - Unknown Error Code
End ---------------------------------------------------------------------
And please tell me if some of this should not be public :S
v
