Quote:
Better to use it than the alternative, his advice is just to keep an eye on it. the old man has a HSV GTS and it doesn't use oil anything like that beast. I guess you need to remember that the engine is a highly strung normally aspirated engine.
Motors that use oil are usually those that are designed to rev hard and high and *need* to rev hard in order to get moving. The R36 does not need to be revved hard in order to get moving as it has plenty of low end torque. I had a Subaru Liberty 3.0lt B Spec and *it* used quite alot of oil due to the fact that you *had* to rev it to get it moving due to a lack of low end torque. The R36 is no such beast.
Quote:
Have a look at the outputs from the '92 GT-R which from memory was a inline 2.6 6cyl, twincam, Twin turbo with a dirty great intercooler. This thing cranked out 310bhp, now the R36 is near as dam it to 300bhp from a normally aspirated engine!
No, the 310bhp figure was the "quoted" figure that *all* manufactureres from Japan were "supposed" to adhere to back in those days, the 206Kw ceiling as it were. The *actual* power output from these cars was a hell of alot more.
Quote:
Yes it is a great shopping trolley, but anyone looking at these things need to go in eyes wide open.
The he had a look at the carbon build up; thinks that it is fuel related. He did mention that it seemed to be worse if you're using Caltex fuel. I was following my car over Bell's Line of Road in a Lotus and it was blowing out quite a bit of black stuff. I could almost tell every time that the foot went down hard. Having said that, I had to work hard in the 111s to keep up!
The other thing he did suggest was that the engine mounts would not be long for this world, if the car was being driven hard regularly. I looked at a change, but after some discussion decided against it due to the additional vibration etc being transferred to the chassis and subsequently the noise.
The biggest thing that I'll be changing is the tyres. The Dunlop's are ordinary; I can't wait to get a set of Michelin's.
The hardest thing for me was changing the way I drive. I have been used to rear wheel drive brutal cars, but subtle changes to the way that you turn in and get the power down have made huge differences. And if anyone tells you that you can't get the back end out on an R36, tell them they're not trying hard enough. It may not be quick, but it is great fun.
Cheers,
Brett
