1 Attachment(s)
VW Golf GTi 7.5 - missing front undertray
Quick query for the GTi owners.
Check out the attached photo.
I noticed a wiring harness hanging down and visible under the engine the other day. It looks like it is from the oil sensor under the sump. It all looked very dodgy and likely to be easily damaged. I was able to poke it back up and out of the way as shown in the photo but reckon it will drop again before too long. I then began to wonder if there should be a plastic undertray there that might have been removed and not replaced at an oil service. Would someone on here with a 2018 GTi kindly have a look under the front of their car and see if the sump is exposed and visible, and if the oil sensor wiring is tucked up and out of the way ? Cheers
