Safely run power for dashcam?
Morning all, hope everyone had a great Christmas.
I'm trying to run a USB cable from my dashcam to the cigarette lighter power in the centre console. My idea is to tuck the cable under the roof lining, go left to the passenger-side A-pillar, down, then under the dashboard.
From the research I've done, as far as I can tell, the inflator for the curtain airbag is about half way along the length of the airbag, and mounted somewhere in the roof rail - but the airbag is the 'extended' type which goes all the way down the A-pillar.
I can fully conceal the cable if I run it down the door side of the A-pillar, but that would entail running it between the roof lining and the top of the A-pillar cover, which would, as far as I can tell, put it in the path of the airbag if it were to deploy.
My guess is that the safer option is to try and tuck the cable in as best I can between the windscreen and the A-pillar, but it looks like the gap between the A-pillar cover and the windscreen is too tight to fully conceal the cable, and I haven't yet figured out how to conceal the cable where it runs between the bottom of the A-pillar and the side of the dashboard.
My question is - what is the safest way to run the cable down the A-pillar in such a way that it won't interfere with the curtain airbag deployment?
Does anyone have any tips on how I can better conceal the cable, or if there's a smarter way to do it? My car is still under extended warranty, so I'm not keen on tapping into the power that's available at the mirror just yet.
TIA.
