Problem: Ticking Noise under acceleration
Hey guys!
As you may know, i'm running an ABF with an 02A gerbox.
Recently there has been an annoying ticking noise under acceleration only. The noise does not happen when cruising, or decelerating. It happens in any gear, and annoys the bejesus out of me!
I have so far done the following things:
Listened to head and bottom end with a screwdriver - normal operations there.
Taken off and driven without air filter - the ticking noise is not any louder.
Taken off and driven without starter motor (recently replaced) - no difference.
Inspected the extractors for leaks - nothing I can see
I'm now in the process of changing the gearbox oil, so long as I can get the freakin fill plug open, I've already cracked the drain plug, but there's no point draining if I can't fill!
Any other ideas or tests???
Thanks in advance!
SEAN
