Changing VR6 Oil Filter Housing - advice
Hi all,
I've had a slight oil leak for some time and from what I can see, seems to be coming from the oil filter housing, id say more than likely from the (figure 8) o ring. My understanding is that this is a pain in the ass to remove, especially the top bolt connecting it to the block.
I guess the easiest way to remove this would be to pull the front end off, radiator, etc.. and remove accordingly. From what i can see, the 2 bottom bolts should be accessible from under the car. Looking down from the engine bay, you can see the top bolt, is it possible to remove that top bolt without having to go to all the hassle of removing the front end? I'm making the assumption if it was that easy, everybody would be doing it right
HAs anyone attempted this from the top and succeeded? Thoughts appreciated,
