Squeel/Squeak/Grinding Noise - Front End of car
Problem 1: As stated above got a noise coming from the front right wheel and it ONLY occurs when turning right. It doesn't occur at all when driving straight or turning left. However it goes away when braking and turning right but then comes back once the brake is released again. So basically if I turn right without braking the noise occurs. Its not overly loud but loud enough to hear from the cabin with the windows up and be annoying. It sounds like a metal on metal squeal, and doesn't appear to be a bearing as it doesn't get louder with more speed or driving straight etc.
I have tried jacking the wheel up and moving it up and down left right etc to see if there was movement but there wasn't anything out of the ordinary.
Any ideas or solutions anyone?
2nd Part is just a question: I have tried to search this but have had no luck. On my first start up of the day (or if the car has been sitting for in shade or underground carpark where its cooled completely over 4-5 hours) when the car first turns on, it has a whine from what sounds like the turbo. It doesn't sound like anything is wrong just to me sounds like its warming up or something before I start driving the car. It only lasts for about 60 seconds or so and idles at 1,000rpm for this period of time then drops down to the normal 700rpm idle at the same time the whine stops. I always wait for the whine to stop before driving away in the car. It will also make the same noise if I let it sit and idle for around another 2 minutes but the whine only goes for about 5 seconds this time and it will also do it if I take off after the first 60 second whine and I have been driving for 2-3 minutes and then come to a complete stop somewhere like at the lights etc. I hope all that make sense, if its normal then I'm sure you can imagine what I'm talking about. My question is simply is this normal?
By the way its a 2006 Gti model with a Harding Performance Stage 1 Tune if thats of any help.
Thanks!!
