MDI - Maximum Size of Flash Disk - What does everyone use?
Hello everyone,
I have just filled my 64gb USB Flash Disk with MP3 files and it works perfectly, after re-formating in Fat32 file structure.
Initially, the standard Polo GTI Head Unit came up with a MDI Reading Error and would not work, until I used Fat32.
Prior to this I had 32gb disk and that already had the same Fat32 File Structure.
So I found and downloaded a 'HP File Conversion Application' and now the new 64gb works brilliantly.
Unfortunately, it is now full, so I just purchased a USB2 (in a USB3 Case) 128gb Solid State Drive and put the exact same file structure (Fat32) and the same MP3's on it but it isn't working.
All I get is "Media Initialising", for a few minutes when I get bored!
Seems to have power to the case and I presume it is looking at the disc correctly as last time it came up with an error almost straight away.
Any Ideas??
Stephen
RE: MDI - Maximum Size of Flash Disk - What does everyone use?
I use a 320gb portable hdd with usb2. Works fine with fat32.
I just noticed that you are using a USB3 case. That may have a bearing to why it doesn't work.
1TB here and no issues...
