I need help with Wheel Alignment
I am very fussy with wheel alignments...always have been with all of my cars.
I like the car to run dead straight on a straight bit of flat road, with the steering wheel dead centered...
Mine is currently running strange. If I hold the wheel straight and perfectly centered, the car will go off to the left, but if I let the wheel go, it will drop down to the right slightly, but the car will still go to the left!
It feels like it is 'crabbing'...know what I mean??
So I went to two different places today (at over $65 each) to get it rechecked and redone.
Both did a bit of fiddling, but the same still occurs.
I even had the wheel all rebalanced, and rotated to try and work out the issues.
At speeds lower than 70 kms it seems perfect, but over that speed on flat freeways the above reoccurs!
I am now getting frustrated!
I am happy to pay good money to get it done right!!! Any suggestions for GOOD places?
Any ideas??
Thanks guys!
A friend of mine once told me you'll never get it dead straight, simply because the car is not perfectly symmetrical. The gearbox hangs to the left so that might be why it slightly goes that way. Another explanation is there is no such thing as a flat piece of road, otherwise when it rains there would be water everywhere. The roads (more obvious on freeways/highways) taper off to the left from the centre line for the water to head to the drain.
It may hold straight for a while at a low speed, but physics then starts to take over when climbing up (in speed)
When you start mucking around with camber and adjustment you could probably get that straight run.
Sent from my iPad using Tapatalk HD
