Intercooler Discussion - Looks can be deceiving
From here: Intercooler Discussion – Looks can be Deceiving - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
In 2006, APR began development of the APR Front Mount Intercooler System for VW's 2.0T engine. This came after being commissioned by Volkswagen of America to create the ultimate performance hardware for their R-GTI Concept car. A North American Nation Wide Tuner Challenge was held by VW and participation was extended to APR and other tuners in the industry. The results, which were overseen by the SCCA and several automotive magazine editors and journalists, proved APR powered vehicles set the bar by a large margin in all performance categories and the APR prototype intercooler and Stage III turbo system were made available to the public.
In recent years, many intercoolers similar in appearance have entered the market. This came shortly after several overseas companies began copying designs and selling them for pennies on the dollar with any company's name on the hoses and end tanks. Many of these items can be found online using APR's own product photography, but the actual product is a far cry from the original in almost every way, shape and form.
The purpose of this thread is to address the differences between APR's intercooler in terms of performance, quality, fitment, support and more. This will not only help you to spot a fake being passed off as an APR intercooler, but also see the quality and fitment differences of the USA-manufactured APR Intercooler and the competition's overseas-manufactured intercooler. Our testing data will further illustrate the impact on performance, which proves looks can be deceiving.
Intercooler Performance Testing:
To measure the performance difference between two intercooler cores, APR conducted back-to-back testing, on the same day in order to control data as tightly as possible. The test vehicle was fitted to APR's dyno with the room's exhaust and coolant fans set to a controlled value. Six dyno tests were conducted while data logging various engine variables in real-time using APR's ECU Explorer software. Data not available from the vehicle's ECU, such as the pre-intercooler boost and temperature, were collected with extra sensors installed before the intercooler's inlet.
Starting Conditions (APR Intercooler vs “Similar Looking” Intercooler):
- Ambient Temp: 84.9 °F vs 81.1 °F
- Ambient Baro: 29.3 in-HG vs 29.3 in-HG
- Ambient Humidity: 36% vs 35.3%
- IAT in the Intake Manifold: 94.1 °F vs 86 °F
Starting conditions were nearly as identical as possible. However, the "Similar Looking" Intercooler core tests were conducted in more ideal conditions with an intake air temperature 8.1 degrees less. Ambient temperature was also 3.8 degrees cooler.
Testing Information:
- Dyno Run Length: 12 seconds
- Time Between Runs: 5 seconds
- Number of Runs: 6
- APR Testing Time: 3:38:47 PM
- Competitor Testing Time: 5:18:09 PM
The APR Intercooler was tested first. Upon completion of the tests, the vehicle was removed from the dyno and taken to the workshop. The APR Intercooler was removed and the competitor's intercooler was installed. Finally the car was reconnected to the dyno and testing continued.
Results:
The APR intercooler core preformed dramatically better than the cheaper alternative.
By 7,000 RPM, on each of the six runs, intake air temperature was no greater than 6 °F from the starting IAT of each run and during three runs were actually 4.05 °F LESS than the starting temperature of each run. The competitor's core didn't fair so well, seeing as high as a 17.55 °F increase in intake air temperature from start to end on a single pull. See graphs posted below for IAT during each pull.
http://www.vwwatercooled.com.au/foru...a_midpng-1.jpg http://www.vwwatercooled.com.au/foru...e_midpng-1.jpg
By the sixth back-to-back run the APR Intercooler had no problem reducing post IC intake air temperature at 7,000 RPM. Temperature dropped from as high as 330.4 °F down to 103.55 °F. However, the cheaper alternative struggled to reduce intake air temperature below 120 °F by the third dyno run, despite better starting and ambient conditions.
http://www.vwwatercooled.com.au/foru...mpendpng-1.jpg
A six run average showed the APR Intercooler starting with IAT's at 103.55 °F, which dipped as low as 100.175 °F around 5,000 RPM, with a final temp of 104 °F by 7,000 RPM. The competitor's intercooler showed a six run average starting IAT of 103.33 °F which rapidly increased to 114.35 °F.
http://www.vwwatercooled.com.au/foru...eragepng-1.jpg
