VR6 Hydraulic Lifter replacement
Seeking some advice from the mechanically minded
My Bora has had a ticking hydraulic lifter as long as I have had it.
Initially, Depending on the oil used, it generally would only be noisy at startup and after a bit of pretty spirited driving.
Now 20,000kms down the track it pretty much ticks all the time, savagely when cold (especially since the move to Canberra and it's sub zero mornings) and then faintly at idle once the engine is warmed up.
Today I changed the oil and used Shell Helix Ultra 5w40 and it is really noisy now, worse than before I changed the oil.
I know that to replace lifters I need to get access to the head, which means removing the intake manifold and possibly the radiator (and therefore the front of the car) which are tedious but doable jobs for a home mechanic but once I have the cover off the head, how hard is it? Do the cams need to come out (I'm guessing they do, but maybe I'm wrong)? Does anything else need to come out?
Is the replacement of lifters on a 24v VR6 within the realm of a fastidious amateur with a Bentley manual and the wife's permission to buy whatever tools are needed or should I really be sending it to my mechanic? If the mechanic is doing it is this going to cost me a tonne (like more than $500, more than $1000)?
