Who has a recent Caddy and VCDS?
ABS module coding help
I am trying to map out the "long coding" of the newer MK60EC1 ABS module as fitted to various recent VWs. This info has not been published yet. To do this I am grabbing the ABS long coding from different types and comparing the differences. I Don't have one from a Caddy or Polo yet. Any chance someone here has a recent CADDY and VCDS and a spare 5 minutes? If so could you PLS grab me a Full Scan. Either PM it to me or post it in a reply would be great. I dont need you VIN number so erase if you have any concerns. But the rest of the full scan would be good as it helps me to cross reference stuff. Thnx.
Scan from May 2010 caddy Maxi Life
Hi,
Hope this helps.
A recent scan from my May 2010 Caddy Maxi Life,
Seems to be a dodgy rear park sensor! :(
Mike.
Monday,23,August,2010,10:22:30:17284
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 1K0
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 46 52 56
VIN: mix_vw_caddy Mileage: 610km/379miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 PH HW: 03G 906 021 AB
Component: R4 1,9L EDC G000AG 2389
Revision: --H11--- Serial number: VWX7Z0J13N910C
Coding: 0000078
Shop #: WSC 35110 377 00169
VCID: 74C90EE86ED0
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 053 D HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2103
Revision: 51112 Serial number: 00001002051193
Coding: 0000020
Shop #: WSC 35110 666 38454
VCID: 160D146058EC
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 2K3 907 379 HW: 2K3 907 379
Component: ESP FRONT MK60 0101
Revision: 00H13001
Coding: 0021202
Shop #: WSC 35110 377 00154
VCID: F3CB8DF4EBDE
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 JN HW: 1K0 820 047 JN
Component: Climatic PQ35 143 1515
Revision: 00143034 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 79D73FDC49B2
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 01000003704163
Coding: E1884F030004100057000000000000000008FF075C00012000 0000000000
Shop #: WSC 35110 377 08192
VCID: 334BCDF42B5E
Part No: 1T2 955 119
Component: Wischer 160210 021 0512
Coding: 00038805
Shop #: WSC 35110
Part No: 1K0 955 559 AH
Component: RLS 180210 054 0403
Coding: 00209133
Shop #: WSC 35110
Address 10: Park/Steer Assist (J446) Labels: 1K0-919-475.clb
Part No SW: 1K0 919 475 K HW: 1K0 919 475 K
Component: PARKHILFE 005 1706
Revision: 00005000 Serial number: 0 263 004 388
Coding: 100101
VCID: 3A55E0D00C34
1 Fault Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 2
Reset counter: 45
Mileage: 17 km
Time Indication: 0
Date: 2000.00.00
Time: 00:54:09
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AJ HW: 6Q0 909 605 AJ
Component: Z6 AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037UR03G437
Coding: 0023094
VCID: 7F23D1C45796
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CM HW: 1K0 953 549 CM
Component: J0527 053 0111
Coding: 0001034
VCID: 7F23D1C45796
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1T0 920 864 A HW: 1T0 920 864 A
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0J13N910C
Coding: 0018101
Shop #: WSC 03002 959 06940
VCID: 334BCDF42B5E
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 160210F1001940
Coding: ADA01F06000202007401
VCID: 69F76F9C3912
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 1212
VCID: 334BCDF42B5E
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000560
VCID: 48B18A1842D8
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 008B04087F2D8405485A030000C0
VCID: 8021D238AA68
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000560
VCID: 47B389244FC6
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K8045231
Coding: 0500040002
VCID: 65EF63ACD50A
End ---------------------------------------------------------------------
