New one to look for if you want to maintain boost
Hey guys this is the second one now so i thought it be prudent to let you know,1st one was Sharkies Ex polo, which i thought was a one off. Ok 1st Polo presented with lost power and lost boost. i scanned fault codes and luckily it presented open circuit N75 boost controller.Ok found his broken wired thus no control thus waste gate wide open and BAHHHHHHHH flat as 1.8 with low compression flat as.Now fixed the wiring and ran it with conduit with a new N75 posi.One off??? nope. Today i serviced a Pog and during my inspection saw this
http://www.vwwatercooled.com.au/foru...0/02/n75-2.jpg
Now this under idle will rattle against the crankcase breather clamp and cut the wires, saw it 1st hand!!!. This lucky fellow i re positioned N75 destined to fail guys. Quick check and quick fix DO IT!!!!!!!!. All you need to do is loosen the clamp and turn it!!!
JMac
