HELP! Clutch pedal stuck all the way in...
Hi all - your technical help would (again) be muchly appreciated
Would you believe it - after a weekend trip of 350 kms the VR6 just broke down two blocks before reaching my place!
I was sitting in the car with the engine off dropping off a friend. For some reason I was fidgety and pushed the clutch in and out about 5 or 6 times whilst the engine was off.
The pedal area made a wierd (almost snapping) noise and then the clutch pedal just stuck all the way in.
The car starts (its in neutral) but the gears don't engage, so obviously the clutch is not activated.
I found a small black metal rectangle (about 2X3cms) on the footwell which looks like a die-cast piece that has snapped off from something as there are four small unpainted circles on one side.
Any ideas what the problem could be?
Luckily the car is legally parked.
I've got the Bentley VR6 service manual and there is a section on the Clutch assembly. Tomor morning when its light I might try to have a closer look and see if I can fix it myself but I thought someone out there might have an idea what has happened?
The trip was heavy on the clutch as I was returning to Sydney from the Central Coast this evening and the F3 was closed at Mt Kuringai due to the bushfires with all traffic diverting to the Pacific Highway.
So I was in heavy, slow stop-start traffic for a few hours.
