Oil Pump where is the best place to get a new one ?????
AND a new front engine mount or rubber
or has any one converted to a stronger one
talking about the one that goes to the radiator support panel
Hanvic South Yarra or someone local that buys from them for the oil pump.
http://www.hsy.com.au/
otherwise ebay or www.germanautoparts.com
Front mount I run a SuperProPoly one. I got it from SupercheapAuto.
No particular issues with running the urethane mount.
Pete
Check Ebay for Prothane bushings. You can get an entire set of bushes including all engine mounts for US $70.00.
Can't go wrong.
Get a diesel/16V oilpump if you need a new one. Higher volume and pressure won't hurt.
thanks will look around at those places
my relief is stuck ok when it is hot
but about 110 psi at 2500 rpm when cold
will build up enough pressure to make engine break down at
revs when cold
Techtonics front mount, for the street...
http://www.techtonicstuning.com/show...artnum=199.100
Quality products and great company.
still no luck with oil pump
hanvic no longer have then
german auto parts only list mk2 on
any other ideas !!!
Techtonics Tuning.
Oil Pump with 30 mm gears for Solid and Hyd lifter 8v cars
http://www.techtonicstuning.com/show...artnum=115.205
2 liter hyd. oil pump 36mm gears-8V engines
http://www.techtonicstuning.com/show...artnum=115.206
Oil Pump for 2.0L16V engine 36mm hi-volume-German
http://www.techtonicstuning.com/show...artnum=115.208
i have a poly front mount if you are interested??
Ihave 2 deisel oil pumps in transit and shoulfd have them here by friday.
cost $100 plus freight
Andrew :)
:biggrin: There are no MK 1 Golfs in the US, there are RABBITS!
Have another look at germanautoparts under Rabbit.
http://www.germanautoparts.com/Volks...t/Engine/151/1
Andrew's offer above is good too! From memory the diesel pumps have bigger gears.
Pete
