01 Engine |
Trouble codes: |
U111300 - Function limitation due to received malfunction value |
Intermittent |
Date: 2024-01-31 10:03:46 |
Intermittent |
P199E00 - Cylinder head coolant valve Open circuit |
static |
Date: 2024-01-30 08:23:13 |
U000100 - High Speed CAN Communication Bus |
Intermittent |
Date: 2024-01-31 10:05:09 |
U016400 - Lost Communication With HVAC Control Module |
Intermittent |
Date: 2024-01-31 10:24:30 |
U012100 - Lost Communication With Anti-Lock Brake System (ABS) Control Module |
Intermittent |
Date: 2024-01-31 10:24:18 |
U021200 - Lost Communication With Steering Column Control Module |
Intermittent |
Date: 2024-01-31 10:24:25 |
U015500 - Lost Communication With Instrument Panel Cluster (IPC) Control Module |
Intermittent |
Date: 2024-01-31 10:20:21 |
U010100 - Lost Communication with TCM |
Intermittent |
Date: 2024-01-31 10:24:17 |
U014600 - Lost Communication With Serial Data Gateway Module "A" |
Intermittent |
Date: 2024-01-31 10:24:22 |
U014100 - Lost Communication With Body Control Module "A" |
Intermittent |
02 Transmission |
Trouble codes: |
P189300 - Signal wire for gear display in selector lever Electrical error |
Intermittent |
Date: 2024-01-30 08:29:22 |
P189400 - Signal wire for gear display in selector lever Implausible signal |
Intermittent |
Date: 2024-01-30 08:20:05 |
P189200 - Selector lever position detection Faulty |
Intermittent |
Date: 2024-01-30 08:29:04 |
P189000 - Signal wire for Tiptronic Electrical error |
Intermittent |
Date: 2024-01-30 08:55:42 |
U010000 - Lost Communication with ECM/PCM |
Intermittent |
Intermittent |
Intermittent |
Date: 2024-01-31 10:05:45 |
Intermittent |
Date: 2024-01-31 10:08:49 |
U012800 - Lost Communication With Brake System Control Module |
Intermittent |
U012600 - Lost Communication With Steering Angle Sensor Module |
Intermittent |
Date: 2024-01-31 10:07:34 |
Intermittent |
U014000 - Lost Communication With Body Control Module |
Intermittent |
Intermittent |
Intermittent |
P17D800 - Torque limitation due to clutch temperature |
Intermittent |
U040100 - Invalid Data Received From ECM/PCM "A" |
Intermittent |
Date: 2024-01-31 10:06:11 |
03 Brakes |
Trouble codes: |
U111100 - Function limitation due to missing message |
Intermittent |
Date: 2024-01-31 10:07:36 |
Intermittent |
Date: 2024-01-31 10:03:47 |
Intermittent |
Date: 2024-01-31 10:16:03 |
Intermittent |
Intermittent |
Intermittent |
Date: 2024-01-31 10:05:10 |
Intermittent |
Date: 2024-01-31 10:05:51 |
Intermittent |
Intermittent |
Date: 2024-01-31 10:14:28 |
Intermittent |
U111200 - Function limitation due to implausible message |
Intermittent |
Date: 2024-01-31 10:21:03 |
Intermittent |
05 Keyless System |
Trouble codes: |
01330 - Comfort system central control module Please read DTC |
Intermittent |
08 Air Conditioning |
Trouble codes: |
Intermittent |
Intermittent |
Date: 2024-01-31 10:16:12 |
09 Central Electrics |
Trouble codes: |
01314 - Engine control module (ECM) No signal/communication |
Intermittent |
Date: 2024-01-31 10:05:00 |
01315 - Transmission control module (TCM) No signal/communication |
Intermittent |
Date: 2024-01-31 10:07:00 |
