22 Attachment(s)
Amarok Trendline M21 Bonnet Strut conversion kit
Attachment 54741
Remove mudguard screws. They are a 6 point.
Attachment 54742
Attachment 54743
Attachment 54744
Attachment 54745
The front mounting hole needs to be redrilled. 293mm centres. Measure from bolt hole nearest windscreen.
Check brackets for alignment. Do not tighten.
Attachment 54746
The lifting bracket comes in two pieces.
Attachment 54747
When the top and bottom go together, they look like this...
Attachment 54748
Not like this. Note gap top left.
Attachment 54749
Mark a diagonal cut from the front of the lower bracket to about halfway.
Attachment 54750
Attachment 54751
Attachment 54752
I've cut mine at 30mm along bottom edge. It's halfway.
Attachment 54754
Attachment 54753
Attachment 54755
Weld the top and bottom halves together, then cut. It's easier to do this as one unit. The top edge or lifting plate is full length. The bottom bracket is the one that has collision issues.
Attachment 54756
Attachment 54757
Grind off any rough edges, particularly along the top, as the install is 'metal on metal'.
Attachment 54758
Attachment 54759
A quick spray of mat black spray paint and you're set to go.
Attachment 54760
Attachment 54761
Attachment 54762
Finished brackets. Top bracket is full length, bottom bracket is now half length (30mm).
