There are mods available for the 1.0TSI that is in your T-Cross already.
A turbo inlet pipe (TIP) is already available, as is a cold air intake. Front mount unlikely possible due to the limited space in front, as evidenced by the integrate intercooler in the manifold. It is very unlikely you will be able to bypass that as I do not know of any replacement inlet manifolds (with out the IC) for the 1.0TSI.
A tune is already available and Stg 1 will net you 110kw.
Link to the tune and intake bits
Products Archive - Harding Performance
Aftermarket downpipe (DP) from the Up 1.0TSI will likely fit (see Miltek), but no cat back as of yet that I could see.
As an FYI, you don't need to do anything to get the Stg 1 tune. The intake and DP will increase the power slightly beyond what Stg1 will give you though.
