2 Attachment(s)
Pink slip fail - Mechanic says both side inner CV boot leak grease.
Hi guys, I've taken my 2007 Golf V 2.0 FSI to the shop to get the timing belt + water pump replaced.
Then I realised that the rego was due for renewal soon so I asked him to also do a pink slip.
He just messaged me that both side inner CV boot rip leaking.
And he's suggesting to replace for both side the whole CV shaft kit.
- Can you really fail a pinkslip for that? I mean I've taken the car to other places and they didn't look under the car or checked the suspension components. I'm just wondering if he's not trying to hike up the bill. I'm pretty sure the car would pass the eSafety check somewhere else.
- He's a pic, is a replacement really warranted?
Attachment 54465
Attachment 54466
- Also just to make sure I understand. The CV boot is the black rubber part that connect the shaft to the transmission correct?
Based on the his message, only the CV boot is damaged not the shaft.
When he says the shaft kit for 1 side cost $195, he means replacing the arm (shaft) and the rubber part (the CV boot) correct?
Can we only replace the CV boot part since this is what appears to be leaking grease or is it generally better to change the whole kit?
I'm not super familiar with these parts so any insights is appreciated
Thanks
