Disconnect battery for 6 weeks
I'll be going overseas and leaving my Golf R parked for 6 weeks (sad I know).
I want to disconnect the battery for this time so it doesn't run out by the time I get back. I've asked VW and subsequently done countless searches. Apparently you can disconnect the negative terminal and it should be fine. However, I've also read that you should do this while the car is unlocked, otherwise the the alarm may sound when you connect the battery back up. Obviously though I want to keep the car locked when I leave.
Does anyone have any advice on disconnecting the battery, locking the car and not having any issues with the alarm or security system? I'm aware that I'll need to take the cover off on the driver's door handle to use the key to get back in.
