Hi there,
Has anybody replaced their front wheel bearings?
Does the bearing pull out easy?
Cost of the bearing? Would SKF carry an alternative; cheaper?:o
Hi there,
This is not an easy job. While I havn't done one on a T4, I have done 5 or 6 on mk1 & mk2 golfs. I have just looked at the manual & the design is very similar although obviously larger on the T4.
The brg will be a tight press fit in the housing & may need a 10 tonne press to remove & install. You will also need special press tooling & a puller for the ball joints.
The brand of brg is not important as long as it's a recognised brand.
Try your local brg supplier or VW parts place [sometimes they are cheaper]
How many kms has your T4 done?
The wheel brgs can be damaged by someone removing the centre bolt from the drive shaft or even loosening it with the full weight of the van on the ground.
Another thing you will have to do is collapse the torsion bar. Mark it 1st though!
My reason for asking about the bearing is I have noticed a noise coming from the suspension when I gently use the brakes or corner the van around at speed. The noise sounds like a disc pad rubbing; yet I have replaced all pads and had the front discs machined. Van has done 100,000 klms.
I have even had the front of the van off the ground and with wheels turning ( motor running in gear) and checked for any noise.???:?: None.
I know the bearing jobbie is a bigun.
Peter
If a wheel brg is gone it will drone[can'ty think of a better description] all the time & the pitch of the noise will alter as the speed increases ie higher frequency with higher speed. From what you have just posted it sounds like something else.
Yeah, I like that answer... now that you mention it I had alot of problems pushing the caliper pistons back into their housing when I replaced the pads.
Perhaps they need a service kit and a good grease (brake grease) - or maybe just a good flogging like John Cleese did to his car;)?:rolleyes:
Will enquire about a service kit -any ideas were, who supplies same?
Peter
This is a much easier job to do, and very cheap for parts. This kit should be something your local vw aftermarket shop would sell or brake service/repair business.
Thanks Guys for your imput; I feel better now.
Peter:wink:
