:: ECS Tuning :: VW MK4 R32 Ignition Service Kits - Click Here !!!
http://www.vwwatercooled.com.au/forums/
Click HERE to order or for more information.
Make sure your plugs are firing at voltage levels that ensure optimal combustion and peak performance.
If your old coils are tired and unable to do the job, an ignition service kit from ECS Tuning will put some zap in the gap when you need it most.
Our ignition service kits are easy to install and come with everything you need to restore secondary ignition efficiency to fire at voltage levels adequate to get the most from each and every power stroke.
http://www.ecstuning.com/marketing/V...R32_ISK_01.jpg
