Q3 Climatronic in S3 (A3) 2010
Read about doing it here Q3 Climate Control 8P Retrofit | Audi-Sport.net and here [8P] Q3 Klimabedienteil in A3 einbauen - Audi A3 Forum für Tuning, Probleme und Hilfe so I ordered one with heated seat button for my S3.
Did similar on my MkV R32 by replacing original with an Mk6 one. Looked and worked good so thought why not.
Got one sent over from an UK Audi wrecker :)
Fits OK 2010 S3 sportback....heated seats.
I ground 2.5mm off each side (left and right) on a sanding belt.
Removed the metal clips to make removal easy if required as orig was VERY tight. (doesnt seem to need them anyway)
Removed the switch panel above climatronic.
Removed old climatronic.
Replaced climatronic and switch panel.
Cleared fault codes and adjusted as per earlier post above in vcds for the heated seats..
"with VCDS open the HVAC controller, click adaption, change the value of channel 26 from 65 to 55 to reduce temp".
Working good..:drink:
Looks the same as this now..
Thanks to Arkious for the pic
http://www.parkers.co.uk/Images/Page...6/DSC_0922.jpg
no heated seats
http://www.audi-sport.net/xf/attachm...362-jpg.51251/
