R36 needs new shocks and discs+pads
Hello!
So ive owned this VW R36 sedan for years without having to replace a single part. Now the time has come (reaching 164,000 klms) that the good ol guys at VW service centre have given me a nice little XMAS list of things i need to replace. I would like to not purchase from VW, rather seek your advice on good OEM alternatives.
The below 4 points are what VW said i need done.. any advice on brands, part numbers, and even places on Sydney Northern Beaches to have the work done is most appreciated.
1. SLIGHT OIL LEAK FROM FILTER HOUSING, WILL REQUIRE NEW FILTER HOUSING
2. O/S/F AND N/S/F ANTI ROLL BAR LINKAGES WORN AND REQUIRE REPLACEMNT
3. O/S/R SHOCK STARTING TO LEAK OIL AND WILL REQUIRE REPLACEMENT OF BOTH
REAR SHOCKS
4. REQUIRE NEW BRAKE PADS AND DISCS FRONT AND REAR
I've read DBA discs matched with Remsa pads aren't a bad choice, and also Bilstein B8's for the shocks are a goer. But i seek your advice! Also, should i replace the transmission dog-bone and all of the suspension bushes with performance versions at the same time?
Thanks in advance.
