Results 1 to 5 of 5
Thread: 2009 passat Starting problems
    Feb 2015
    I'm having a starting problem with my VW 2009 Passat.
    I push to start, it turns over then stalls after 1-2 seconds this can happen 5-6 times before it stays running
    I get the following message flash up on my dash screen
    "Steering column lock defective" and
    "engine fault workshop"
    Any ideas?
    Dec 2008
    Sydney/Canberra
    Self explainatory really.
    The Electronic Streeing Coloumn Lock module is failing.
    Get it fixed ASAP before you get stuck somewhere.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Feb 2015
    Thanks, it's been doing it for a while now but this is the fist time it's told me the steering lock is faulty
    It's a fair drama to sort out if you leave until it's left you stranded. Jmac was telling me about one he had in recently.
    If you get it replaced I would be keen to see the broken part to see if they are repairable.
