Newby Caddy maxi van bt/sat nav options
Hi guys,
I have a new maxi van due from the docs in a couple of weeks and have added the Bluetooth as an extra. I believe it is a re badged Bury touch screen model from what I have read.
I have also read that the RNS 510 model H is the latest compatible model of SatNav compatible with the caddy.
My questions are:
1. Is the Bury touchscreen by VW a good option in terms of quality?
2.If I buy the RNS 510 do I still need a separate bluetooth device such as the Bury?
3. If I still need a bluetooth kit does the Bury integrate well with the RNS 510
4. Can I install the RNS 510 and connect up to the Bury easily, i.e a simple walkthrough guide available?
Thx
- You may not post replies
- You may not edit your posts
Forum Rules
