Results 1 to 3 of 3
Thread: VW Golf engine swap from 1.4L TSI to 1.2L TSI
    Dec 2023
    Karalee, Queensland
    Hi, so I'm working on my 2010 golf, 1.4tsi 118kw engine, it's running very rough on idle, and i've replaced everything from sparkplugs, to coils, to intake air regulating flap, oil cooler(coolant mixed with oil but not a headgasket issue) and the turbo, but the problem still remains. I was planning on checking the injectors too but it's in such a ****ty place, no clearance unless I remove the intake manifold(which I thought would be easy enough, but I have to remove the intercooler too to get 1 bolt out of the intake manifold, and I might even have to remove more stuff to have enough clearance to remove the intercooler, I can be wrong tho, but I tried). Anyway, I found a same model golf with more than half the mileage of what's on mine but the engine is different, a 1.2L 77kw engine, so I made the decision of just swapping the engines, rather than putting any more work on the other engine. All the wirings and fluids are done, but I can't seem to start the engine. I checked my fuel, all good, for spark...I think I'm not getting spark, I used a timing gun to test if I'm getting power on my coils and it seems like I'm only getting a response from no3 coil, and nothing else. Should I replace my coil pack? or am I even in the right track? I'm thinking maybe it's an ecu problem? cos I tried using the ecu that came out of the 1.2L engine but I'm having issues with the immobiliser, so I used the original ecu that came with the car, I'm not sure if it's compatible with the new engine tho because the new engine doesn't have an intercooler. Would really appreciate any advice. Thank you very much
    Mornington Peninsula, VIC
    I would start with using the ECU from the donor car; cam and crank sensors may have different waveforms between the two engines; it should still start and then stall out from the immo
    Was the harness from the donor or the original car?
    PS might be a good idea to move the thread to the Golf section.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Dec 2023
    Karalee, Queensland
    Thank you very much, I'll try that. For the wiring harness, the other half is from the donor, and the other half is from the original car, everything fits except for one plug, because the original exhaust pipe has an oxygen sensor in it while the donor engine doesn't have a sensor on the exhaust pipe, so that must be it...
    Thanks, yea I got lost in the forum and wasn't really sure where to post it haha, Ill do that, thanks
