Results 1 to 4 of 4
Thread: Hello.
    Jul 2022
    Barossa Valley
    Hello.
    Hi.
    I've finally joined as I'll probably need specific advice. Very very soon. Hopefully I can contribute some as well.
    I've got a 2011 MY12 Jetta TDI which I've personally put over 300,000 kms on.
    I've just bought a 2009 MY10 Jetta TDI with quite low kms.
    I had a 2006 Jetta previously.
    I like VWs, I like sedans and I like tinkering.
    I had a RNS510, A 9w7 a Hex-V2 arrive on Friday. The newer Jetta has a flat battery today after fitting the RNS510 and updating the firmware.
    I've got another RNS510 arriving this week some time and a loom kit for the 9w7 (for the older Jetta).
    Jul 2022
    Barossa Valley
    Turns out the flat battery after the RNS510 install was a one-off. I performed the firmware update and reloaded the maps. The firmware I got from here, the one with the custom HDD partition.
    I can only presume the unit got confused by all the restarting.
    Mornington Peninsula, VIC
    Welcome!
    It might still be good to check the gateway version you have to see if it's a known version to cause battery drain.
    Do an auto-scan and check the address 19 details; it should look like this.
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
    Component: J533 Gateway H56 1682
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Jul 2022
    Barossa Valley
    According to the scan report I saved, I have it is as follows;
    Part No SW: 7N0 907 530 C HW: 1K0 907 951
    Component: J533 Gateway H37 0614
    The car seems to be behaving itself. Just a flat battery on the morning after install.
