Results 1 to 9 of 9
Thread: 2011 Passat Fold on Lock mirrors stopped working.
    Nov 2019
    Loftus, NSW
    Hey all,, Passt C3, Highline 2011, 3.6.
    Bought the Passat 2 weeks ago and the power mirrors folded on locking everytime without fail and unfolded on unlock.
    I adjusted some lighting settings etc in VCDS & it stopped, Ive tried every thread i can find and every VCDS sequence listed and cannot for the life of me get the "Fold on Lock"mirrors to start working again.
    I somehow managed to overwrite my first VCDS log and as such can work out what i changed in the meantime,
    Would love some assistance...
    Check the vcds debug log.
    Find what you did and reverse it.
    Will be adaptation rather than coding I would suspect.
    Nov 2019
    Loftus, NSW
    Thanks mate,,
    ,i'll give it a crack and let you know..
    Nov 2019
    Loftus, NSW
    no love...
    @Kamold, thanks mate,, tried that but still no luck..
    Reset values to the following... Still no luck,,, any ideas.. is there a possibility its just a key assignment setting etc?
    Address 09:3AA 937 087 E recoded (Long Coding)000800000000000000180280540029F421D50088626 D8D60E48046240041
    Address 46:3AA 959 433 recoded (Long Coding) 01900A00D2830E76300494157008DFCE107801
    Address 52:3AA 959 702 A recoded (Long Coding) from 0013B6
    Address 17:3AA 920 870 C recoded (Long Coding) from 161F01 Sunday,17,November,2019,16:29:51:62939
    Address 42:3AA 959 701 A recoded (Long Coding) from 0013B7
    Have you checked the driver's door controller adaptation that would have been needed to enable fold initially?
    Nov 2019
    Loftus, NSW
    Yeah i reset all the adaption back to original also...
    Still no luck,,
    also tried the security adaption change from 90 to 95/99 but it comes up with a hexidecimal error thing,, i couldnt work out how to enter it in the required format.
    Nov 2019
    Loftus, NSW
    Tried this adaption but the hexidecimal error comes up..
    Originally Posted by TBAx
    Depending on the modules generation you can either do it with VCDS or need to modify the EEPROM (not possible with VCDS) to enable mirror folding.
    You can determine the version by checking the label file name for module 42 in the Autoscan:
    MAX3 - will require EEPROM change
    GEN4 - possible through adaption
    For GEN4 it goes like this:
    ECU 42 > Login: 04354 > Adaption > Channel "(9)-System_Parameter_0-System Parameter Byte8" > set value to "95" or "99"
    90 = default value
    95 = mirror folding via keyfob and automatic opening on ignition on
    99 = mirror folding via keyfob and automatic opening on driver door open
    Nov 2019
    Loftus, NSW
    90 = default value
    Nov 2019
    Loftus, NSW
    Ok,
    Sorted,,,, i found the tail end of a thread refering to a differnet adaptation method,, it still gave the hexidecimal note so i tried entering a few via an online converter , the conversion factor from hexidecimal to "base 24" converted the E9 required to 9H so in entered it and viola! it works ,, I will do a new scan and up load the full thing for anyone whose interested.
    Short version of the fix is as follows..
    Goto module 42, unlock by going to security tab (Security Code: 04354).
    Goto adaptation
    find
    (2)-System_Parameter_14-System Parameter Byte1, change E0 to E5 - open with ignition
    or
    (2)-System_Parameter_14-System Parameter Byte1,change E0 to E9 (Try entering 9H if it asks for the hexidecimal input) open with door
    Save
    Make sure convenience is set in the MFD.(as applicable, mine doesn't specifically list the mirror fold)
