How would that work on a vehicle that direct injects into the combustion chamber?
I think peoples aversion to ethanol / alcohol is based on hearsay rather than fact.
If you want to produce some big power numbers, then ethanol will get you there, but for E85 you'll need to be able to flow about 30% more fuel through the injectors and change some ECU parameters to take advantage of the 105ron octane on offer.
The mixture will burn leaner because of the Oxygen in the molecular structure.
Ethanol is a clean burning fuel & also has cleaning properties (decarbonising).
If you wish to experiment, you might wish to start with E15 - about 11l of eflex to 44L of 98ron which will give 99ron. You need 22L eFlex + 33L 98ron to get above 100ron. You could do this differently & buy 100ron e10 from United petroleum if one of the 3 stations that sell it is near to you.
