thanks, interested in your impression that changing at 5000rpm is better, I looked up the figs from APRs site to see how our impressions compared with the figures and to provide bit of a further record of the improvements for those considering. Looking at the power and Torque graph for APR stage 1:
TORQUE - there looks to be about 340Nm from 2000 rpm (assuming graph slope doesn't change much b/w 2500 and 2000 - graph doesn't go below 2500). This reflects to me the impression that from about 2000 it feels significantly stronger than stock and again unless there is a big fall off b/w 2500 and 1500 rpm, I expect that even down to 1500 rpm, Torque is at least at the old peak of 280Nm. This also reflects the impression that it feels pretty tractable right from 1500rpm:P. Torque climbs steadily from 2500 up 3300rpm at its peak of 402nm and then stays pretty flat until about 4800 (at peak power) where it starts to drop away more steeply, noting that it stays above pre upgrade peak of 280nm right thru to 6000rpm.
POWER climbs steeply all the way from 2500 to 4800rpm where it is at its peak of 189kW and then stays pretty flat thru to 6000rpm, only losing about 5-7% in that range:cool:.
From 6000 to 6500rpm though, power drops of more sharply losing a further 10% in 500revs down to 160kW and Torque drops off a further 20% to below 240Nm. So the drop off in both power and torque is significant from 6000rpm onwards and you also hit the rev limiter much beyond that - gut impression that there is limited value in taking it beyond 6000rpm appears correct. Likewise with power peaking just before 5000 can see why 5000 feels right. Nonetheless there does seem a reasonable basis to take it through to 6000, or 5500 at least.
With all this torque in this thread about exhaust systems, wish we could get one that would make our Tigs sound like this
http://www.youtube.com/watch?v=vOYkj...eature=related
:bowdown:
In all seriousness, apart from some better gearing, 300 or so KW and ........... the Tig needs a nice note to go with all this go.
I wonder if we could hook up some speakers underneath the body, link it to a program that tracks the revs and plays the appropriate exhaust soundtrack:eek: Mind you dont laugh, car makers are working on sound tracks for electric cars - they're too quiet.
