It's just surface rust. Have a drive around the block and your normal braking will grind back the rust and the rotors will be shiny again.
Sent from my iPhone using Tapatalk.
Is this normal? Gave the wheels a good spray and within 2 days, all 4 discs are now badly rusted!![]()
Take one of the wheels off and see the rust on the hub !!!
You will quickly forget about surface rust on the discs![]()
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
that is perfectly normal .. in fact.. after spraying the disc, there will be rust within the hour.
Thanks so much for your quick replies. I contacted VW and they confirmed it too. At least my missus won't be having any more kittens!
I found that if I washed the car and didn't move the car till the next day the brakes seize. Makes a definate bang when they free up when I move the car. Now I always take it for a quick spin to diperse any water from the brakes. First time it happened I siht bricks.
Golf R, Rising Blue, 5 Door, DSG and some extra fruit.
Viagra on 4 wheels !!
"If you can't fix it with a hammer then it must be an electrical problem"
Don't put the handbrake on
Assuming your parking spot is level
Every VAG I've ever owned has done this, worried me at first like yourself but the dealer pointed out even the cars in the showroom had it. Something you'll get used to!
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
Get use to it.
Will also happen when you're car is parked outside under heavy rain.
MY11 Tiguan 147TSI (SOLD)
