It is normal. It will start in first when you select "S"mode.
Look in the MFD for the Alarm setting.
Hey Guys, i've had my tiguan for a couple of weeks. My 09 tiguan has all the options (except for xenons and MDI), i've thoroughly enjoyed it so far but have the following questions:
When you put the auto (non DSG) in D, it always starts off in 2nd gear, just want to know if its normal? It will however start off in gear 1 when put in S (Sport mode).
When hooking up the tow bar, is there meant to be any indication that the car knows that a tow has been connected? I briefly towed a small boat but could not notice any indication, although it towed it easily which was very pleasing.
Also, how do you know if you have an alarm installed in your Tig?
Thanks for your help![]()
Look for the 3 character Option Codes on the sticker located in your Service Schedule booklet and punch them into this website:
VW Group Option Codes Decoder
It'll tell you exactly what options you have (including alarm) if you have it.
Alternatively, the alarm also includes motion sensors inside the cabin.
So lock yourself in with remote and wave your arms and legs like this and see if it goes off!
http://youtu.be/JiLegWBXBew
In the Mk5 Golf you could still open the front doors, even if doors are locked with remote!
So it'll go off that way too! But not sure with the Tig!
Haven't bothered to read the manual (just like you hippyhippy)!![]()
MY11 Tiguan 147TSI (SOLD)
just tried it .. but the website doesnt say.. there are other options which this doesnt show.. i'll check my MFD later... also I dont seem to have that alarm button that you can see in the manual.
B0R = Component parts set, complying with vehicle type for Australia, various parts
C9U = Alloy wheels 6.5J x 16
G0R = 6-speed automatic transmission for four-wheel drive vehicle
HU5 = Tires 215/65 R 16 98H
J0L = Battery 340 A (70 Ah)
D91 = 4-cyl. turbo diesel 2 gineEZTD 03 kW (4V) TDI common rail; Base engine: TG3/TJ3/TU3/TL4/TP4/TM3/TW3/TR4/TS1/TN5
2ZB = Leather multi-function steering wheel
1NP = Wheel center cover
5RV = Right exterior mirror: aspherical
5SJ = Left exterior mirror: convex
TG3 = 4-cylinder diesel engine 2.0 L unit 03L.A
QG2 = No possibility of activating service interval prolongation
8AY = Radio/navigation system
8GU = Alternator 140 A
8ZH = Antenna for AM/FM reception, "diversity"
1X1 = Four wheel drive
1LJ = Disc brakes, front
1AT = Electronic stabilization program (ESP)
1G9 = Space-saving spare wheel for temporary use, radial tire (5-hole)
