First impressions - one month on
I've written down in no particular order a number of things that have struck me in the first few days of driving the Tiguan. Sometimes wrong. For those of you already with a Tiguan, it might evoke a "oh yeah, I saw that too" - and might actually help those whose has the Tig on the "to buy" list get a little more familiar with it. Add/comment as you will
1. Glovebox is big enough to fit a Melways - a first - but then the VW owners book will not fit. Maybe I can fit the 147-under-seat drawer.
2. Low beam Headlamp bulb has a little cover with the VW symbol on it. Cute.
3. Storage in doors can take large bottles, and even larger still. And centre console. I think it has enough cup holders to satisfy all.
4. There's an odd tie down strap under the passenger front seat (TDI103).
5. There's a power socket audio input jack in the console (nice) but no instructions - or lost in the zillions of interior variants shown in the manual.
(did anyone read about the petrol powered engine preheating system connected to the climate control??)
5. Boot light is atrocious - too low down. Will have to install one up high. I think I saw a Golf thread where someone has done this.
Highway driving dynamics are good, behaves like a well controlled FWD.
5. Brake pedal is overlyu sensitive and very high - hard to shift easily from accelerator to brake. Treacherous at high spead when you cover the brake midcorner, and bit annoying in daily use. Might see if its possible to lower it.
6. The brake lights come on immediately you touch it before the pads touch - which might trigger the auto transmission downshift, so I won't complain.
7. Tend to drive out of the headlamp range at 120km/h, but I hadn't up - adjusted the headlamps, so I'll have to recheck this before passing judgement. It would benefit from brighter high-beam bulbs, I'll have to find out what the brightest Halogen H7s are available that aren't just blue-bling.
8. I miss the fingertip control stalk for MFD from the basemodel Golfs. Its surprisingly easier to use than the steering-wheel mounted ones
9.Reverse lamps are just above the bumper. The inner white circular taillamps are actually a dummy.
Climatronic (automatic Climate Control) works very well - simple and intuitive.
10.The LED lamp next to the demister setting on the mirror adjust knob does not light up when the demister is on. Its a security lamp.
11.I should have bought floor mats (oem or aftermarket) before I took the kids to the beach.
12. The speedo massively underrreads. Next purchase: VAGcom tool to fix this.
13. no fold up table or even seat pockets on base model for a car aimed at kids.
14. cup holder in rear floor of console won't survive my 6 yo stepping on it
15. hard cheap plastics on the rear door trim (but not on front doors).
16. door fabric looks like it would be shabby very soon
17. door grip is frosted plastic, will chip and scuff with rings etc.
18. Tow bar is too expensive, waiting on Hayman Reece cheaper solution.
19. No LED tailights (this is a new model and other VS models have this feature), no halogen interior map lights
20. Cheap looking unpainted rear bumper
21. Whack your left foot to the left and you hear a flappy unsecured panel noise - sounds like poor build quality
22. Brilliant auto transmission. Smooth shift, downshifts just right.
23. TDI a dog when cold. I drive into traffic (down hill) from my driveway in the morning. When accelerating when cold, nothing happens. Panic look in rear view mirror. Putting it into "S" (starts in 1 not 2) helps a little
EDIT 24. 2000km on the clock now getting 6-6.5 l/100km in the peak traffic to and from work, impressive.
EDIT 25. Can't figure out How to reset the ø2 average fuel economy reading every time I fill up. It seems to only reset when the speedo reaches 9999km, which is not terribly useful.
EDIT 26: Kick your left foot to the left, the side of console kick panel makes a horrible loose flappy sound
TDI tiguan in the drive. ParkAssist, comfort, fogs
Service every 15,000, new fault code every 7,500km
