Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
Thread: New to me 2010 Tiguan
  1. #31
    Mar 2020
    PERTH
    Changed Haldex oil, filter and cleaned the motor screen.
    No evidence of this ever being done in 155,000km. Looking at Europe videos I was expecting a nightmare scenario only to find darkish nice smelling oil and almost no fouling on the pump motor screen. Main filter was dark compared with new replacement.
    Prior to this I checked the operation by watching my daughter dump it on wet grass going uphill and the back wheels kicked in very clearly with little front wheel spin.
    My suspicion is in 10 years this was the first time the 4 Motion has ever operated on this car hence the very clean system lacking in clutch debris clogging up the system. In Europe on slippery icey roads the system would work a lot harder more often unless you were going off-road in Australia.
    Much easier and quicker job than I expected. Only an allen key easily fits the filter cover above the exhaust. All bolts are tiny 4mm mainly. The rest are easy access on this Gen 4 model.
    Definitely an easy DIY.
  2. #32
    Mar 2020
    PERTH
    Engine oil and both diff oils changed today - both surprisingly easy jobs.
    Last but not least is the ATF. Then every fluid will be new.
  3. #33
    Mar 2020
    PERTH
    Can anyone tell me if a full size spare wheel will fit in the spare wheel space or is it space saver only?
  4. #34
    Pacific Paradise QLD
    Quote Originally Posted by Perthdisco View Post
    Was a big thread a while ago with instructions on how to do it as to padding up the floor for a full size spare Go back through the threads
    After 16 pages of looking I found this
    Best way to fit a full size spare in the boot
  5. #35
    Mar 2020
    PERTH
    Thank you greatly Hillbilly
  6. #36
    Mar 2020
    PERTH
    Now with all oils changed, new tyres and wheel alignment still have a droning warbling road noise from rear tyre area when driving.
    Is this normal maybe? Wheel bearings are ok.
    Suspect a small exhaust leak as a possible culprit. Are cracks a known issue?
  7. #37
    Jan 2018
    UK
    My 2010 tig had a wheel-bearing drone when I bought it. At that time it had 82,000 miles.
    It has now around 162,000 miles, and the drone is still there... I still suspect a wheel bearing, and I did buy a new hub in preparation, but it never got worse, so I live with it.
    Yooj
  8. #38
    Mar 2020
    PERTH
    Now thinking the drone is exhaust related. Does the rear muffler ever have problems in these to cause a drone noise?
    Have now changed ATF and filter. Got just over 4 new litres of Toyota T-IV into it. Quite an easy job using a $10 Bunnings pressure sprayer to push the new ATF in. I used a hand held heat gun to read the ATF pan temp with engine idling for the right fill level.
    158k kms and the original oil was barely recognisable as being pink. The magnets in the pan were heavily coated with a few mm of metal paste.
    As I’ve got 3 litres of new ATF left over the best bet would be in another few months to drain out exactly what I have new and refill since I know now the level is perfect. Will be close to a full change then.
  9. #39
    Jan 2018
    UK
    So you flagging the vibration that you are experiencing, which appears to be somewhat similar to mine, has caused me to resume the research into the possible causes... one thing which I think could be a reasonable candidate is the vibration damper couplings at either end of the propshaft. I don't think I came across a Tiguan with the symptoms, but there were quite a few Audis with quattro and VW 4 motions which had a drone type vibration around 2.5k rpm, which they cured by changing predominantly the rear damper, but some changed the front damper.
    Anyway, this might be one avenue to pursue.
    Yooj
  10. #40
    Mar 2020
    PERTH
    Quote Originally Posted by Yooj View Post
    Yooj
    Yes that’s literally all that’s left as new tyres, all oils changed and no worn bearings. Either the muffler has collapsed or the coupling as you suggest.
    It’s a speed related drone rather than engine revs
    P.S. the gearbox now changes beautifully so smooth up or down with the oil change
