Originally Posted by
ploz58
Also on that point of Flat batteries, as the tig has no key entry how do you get into a locked car with a flat battery??
regards
Phil
You're about the 10th person I've seen make that mistake. I could just be rude and say "if all else fails read the instructions" but cos it's Friday I'll take it easy on you:
There IS a key hole BUT it's covered with a little clip on cover at the end of the door handle. Open the cover and use the key OK
Derek
Alexandra
2022 R-Line Golf Mk8 in Kings Red Metallic
Previously 3 Tiguans 2008, 2013, 2017
