Results 1 to 9 of 9
Thread: Towing with 2.0 TSI 132kw & 280nm 4motion
    Aug 2016
    New South Wales
    Hi all
    Just wondering if anyone has experience with a towing weight of about 1200-1500kg with a 2.0 TSI Tiguan.
    Looking at putting a tow bar on mine to tow a small Mazda race car on a tandem trailer. All up weight including the trailer would be maximum around 1500kg.
    Thoughts and how would a TSI go? Anyone towing a similar weight with a TSI petrol?
    Thanks
    Nov 2014
    I've done more with less (old FWD, less torque, same weight)
    Main thing is where are you towing, if you are running up and down the majors it is pretty easy, city is just about keeping your wits about you as you can't rely on your breaking distances being there as someone thinks it is a good idea to jump your lane (but that is the same with any towing) If you are doing lots of hills where you don't get the run up then you may be frustrated, although the torque is very flat which is a huge help, but it will still do it
    Someone else can comment on the gearbox, but you are comfortably below the manufacturers rating
    Most cars it is just important to get your tow ball weight right, especially if you have hydraulic brakes, so you may find yourself doing experiments for position
    Edit:
    Short overhang will help it tow nice as well
    Aug 2016
    New South Wales
    Newcastle to as far as Wollongong.
    Newcastle to Brisbane
    Newcastle to Bathurst
    That will be it.
    I just recall towing an empty caged tandem box trailer with my 2013 Camry and it was crazy on fuel and hunted for gears like mad and really struggled. It was a 2.5 petrol.
    4 cylinder Camry's have no torque - hence the gear hunting and struggling. Im sure it would have been a much more enjoyable experience if you had used a Aurion with the 3.5L V6.
    The 2.0TSI will do a much better job of handling the weight of a trailer, but in general the DSG gearboxes aren't great for towing (on the open road they are fine, but low speed and maneuvering they aren't so great due to the twin clutch gearbox). A traditional automatic with torque converter is a safer option for towing.
    Aug 2016
    New South Wales
    The DSG I can handle as it will be 80% highway. Just didn't want to be going up hills being totally frustrated
    Erskineville, NSW
    The only thing that would concern me is the towball weight
    Aug 2016
    New South Wales
    That is manageable by how the car is loaded either frontwards or rearwards or less deep into the trailer. Just hoping the 2 litre petrol has enough guts to pull
    it happily.
    Quote Originally Posted by overtaken View Post
    it happily.
    If not - get it tuned and you will release another 80nm or so from the engine.
    Erskineville, NSW
    it happily.
    For comparison (perspective is always wonderful)
    Tiguan 132kw / 280Nm
    4.2L V8 VB Commodore circa 1979 (great towcar providing you could keep the fuel up to it) 87kw / and around 240Nm torque
