Results 1 to 4 of 4
Thread: Looking for second hand Tiguan 255/55R17 alloy wheel
    Apr 2024
    Bendigo, Victoria
    Hi all
    Does anyone know where I can purchase a second hand rim for my 2015 Tiguan that will fit a 235/55R17 Tyre.
    I have attached a photo of the type of alloy wheel I am after.
    The part number is 5N0601025AJ8Z8 and from what i see online there aren't many second hand alloy wheels available.
    Help is greatly appreciated.
    Attached Thumbnails Attached Thumbnails Looking for second hand Tiguan 255/55R17 alloy wheel-images-1-jpg
    Pacific Paradise QLD
    As I said look at Facebook Market place and the Ebay one mentioned in your other post would probably fit
    Rims come in inch widths like 6, 6.5 or 7 inch Tyres come in MM width 195, 205, 215, 225, 235 etc so if its the correct rim width various tyres will fit it
    Look on the back of yours on the back of a spoke for a part no which is a combination of letters and numbers, like AEO19453 B or similar, then get hold of seller and ask if they are both the same.
    Usually has another set of figures 17 x7, 5x 112 or similar which gives rim diameter, rim width and stud spacing
    Apr 2024
    Bendigo, Victoria
    Hi Hillbilly
    Yep I have looked on FB and EB and the only one I found, the seller was only willing to sell all 4 rather than the single wheel.
    Hence I am hoping someone here can point me toward someone who has a second hand alloy wheel.
    Jun 2007
    Sydney, Australia
    The wheel you have there is a "Philadelphia" 5N0-601-025-AJ 8Z8
    It is identical to 5N0-601-025-S 8Z8
    Tech details -
    Size - 7J x 17H2 ET43
    Bolt circle - 5x112
    Center centering - 57.0mm
    Originally fitted to VW Tiguan 5N 2007-2016 with 235/55 R17 tyres.
    Being over 8 years old now the chances of finding a good example will be very small. Maybe buying all 4 and flogging the other 3 off later is an option.
    Flipper Dog
    Now - T-Roc R, Audi Q5
