Results 1 to 10 of 13
Thread: replacement brake pads (help?!)
    Aug 2006
    Far North Qld
    at a recent wheel alignment, tyre place noticed couple of my discs were scored and might need machining. Car has done 36K
    Does anyone have any suggestions for AM pads (and/or rotors), as OEM through VW are on the exie side?
    many thanks in advance
    Jun 2009
    ECS has rotors and the EBC pads are apparently very good.
    I believe there is a supplier of EBC pads on here (GSL RallySport)
    http://www.vwwatercooled.org.au/newf...ad.php?t=24856
    ECS Oem brake equipment:
    http://www.ecstuning.com/Volkswagen-...T/Braking/OEM/
    Adelaide hills, SA
    Also VSI imports stock the parts for EU cars. They supply ATE brake parts at good price.
    Jul 2007
    Canberra
    I'd definitely recommend EBC greenstuff pads. A lot less brake dust over stock and much better stopping power. You should be fine for rotors tho, they should just need a skim.
    Forever blowing bubbles.
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Pullstarter View Post
    Glad I'm not the only one who thinks there's excessive amounts of brake dust generated from these cars/pads. My alloys require constant cleaning to keep them well shined and not looking rather dusty!!
    I wondered if using the "autohold" had anything to do with excessive brake dust?
    Dec 2008
    Sydney/Canberra
    No, it wont. It's not in operation for long enough to cause any noticable drag.
    Also, FWIW don't machine rotors on a European car. The Europeans have different ideas on how they should wear, and believe that pads and rotors should be replaced together, as the rotors are made of a softer metal to maximise braking performance. If you machine them, you'll probably take enough off them to render them useless.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2007
    Canberra
    Quote Originally Posted by Umai Naa!! View Post
    Sorry Umai but this is absolute rubbish! Any disc can be machined as long as it's above minimum thickness after the machining and no decrease in brake performance will result. Ask any of the specialist mechanics on this site and they'll tell you the same thing.
    Dec 2008
    Sydney/Canberra
    I just might happen to be one of said specialist mechanics
    '01 Beetle 2.0
    Feb 2010
    Revesby, NSW
    Quote Originally Posted by team_v View Post
    Has any of the Tig use these pads?
    Jul 2007
    Canberra
    If that's the case then you disagree with EVERY other specialist mechanic I've ever met. But if that's your opinion c'est la vie.
