Results 1 to 10 of 30
Thread: Daytime running lights
    Sep 2011
    Townsville, Nth Qld
    Hi all.
    Have MY11 Tig with halogen (not HID) lights, and am wondering if there is a coversion that anyone has found for the fog-lights to be used as DRL's in conjuction with front park ("side") lights? If so, is this legal as I have personally been pulled over by coppers for aftermarket LED DRL's I had on previous car (thought they were the foglights so was going to book me). Can anyone point me in the right direction for the VAGCOM procedure to re-program these (and side-lights) as DRL's also? I'm sure I've seen it somewhere (on Ross-tech or a link to a Forum), but have been searching everywhere and can't find it again
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
    London
    Hi there check this link out it contains most of you what you asked...
    How to disable or use the fog lights as Daytime Running Lights DRL on VW Jetta
    Unfortunately though, if you use the fogs during the day, technically you'll still fall foul of the law unless you change the bulbs over to LED equivalents which I've seen on the internet and on other cars. But then you use your foglights as these cannot be used in the fog.
    2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
    Jul 2010
    It's in here (as with other tweaks):
    http://www.vwwatercooled.org.au/foru...ons-57346.html.
    Should've Google searched using "VCDS and Tiguan" combo.
    Yep changing the bulb to non-fog type helps.
    Certainly haven't had any issues with mine to date.
    See my signature below for pic of my LED DRL fogs.
    MY11 Tiguan 147TSI (SOLD)
    Sep 2011
    Townsville, Nth Qld
    Cool, thanks guys.
    London
    Ok so if I get this right you've changed over your standard halogen fogs to LED DRL equivalents and effectively lost the conventional foglights? I'm actually interested in this mod as a viable alternative to finding a good location for separate LED DRL after-market modules but don't want to compromise on visibility in thick fog. Have you driven in dense fog yet and found the LED fogs inadequate?
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by Naresh View Post
    Hi Naresh,
    so, typing this all again because had to refresh and login again (frickin' F.R.E.D's). Dead right, that is my intention once I find LED fogs similar colour to the park/side light globes I've already replaced. Have driven in fog and experimented with just low beams (with OSRAM 65W offroad globes), just fogs, and both together and there is no appreciable difference IMO. Might be different with HID's or higher Kelvin (white or blue appearance) globes in conventional headlamps though, as they won't penetrate as well as the lower Kelvin (yellower) globes. Will let you know how it goes. I assume Aussietig has been through all this so would probably have some (as always) well-informed opinions.
    Jul 2010
    No sorry ... I live in the urban jungle. So fogs are pretty much useless to me anyway (like most options I've ticked, in hindsight).
    So I've been happy to lose all conventional fogs for DRL functionality. So Beckham over Rooney I suppose!
    I've also coded mine to light up (at night) on one side (like non-blinking indicators) when cornering or indicating.
    LED bulbs are definitely inadequate.
    Kelvins do jack. It's more the lumens (output) that fails you with LEDs.
    Jul 2010
    Quote Originally Posted by Tiggy1 View Post
    Just as a heads up ... putting LED bulbs in the fog will trigger a bulb out (yellow light) warning on your MFD.
    Couldn't be bothered trying to fix this, since most people haven't even got a solution for the Tig the rear licence plates.
    So be prepared to live with that if you want to proceed.
    Perth, WA
    Excellent, will get some from the same seller you got yours from!
    Cheers!
    MY11 Tiguan, 147TSI, Pepper Grey, DSG, Panoramic Sunroof, RVC, Bluetooth, MDI...
    Sep 2011
    Townsville, Nth Qld
    Hi.
    have riveted resistors to couple of handy spots near fogs - pity the leads aren't a bit longer, as I had to turn my RH foglight upside down so I could get it to reach! Got them reprogrammed as DRL's when I had flappy paddle steering wheel fitted and all working good. My LED park lights still throw an error occasionally, but if I flick the light switch from Auto to Parkers on and back it clears the error (until I shut the car down again). Must be borderline as I said in earlier post. Anyways, no biggie and might look at trying some others down the track
