Results 1 to 5 of 5
Thread: “Airbag fault” after battery change
    Mar 2019
    Hi guys,
    Have an airbag fault error immediately after a battery change in 09 Tiguan. After hearing about costs to clear the fault at a mechanic was wondering if anyone had other recommendations. Have read about VAGCOM VCDS and obdeleven but was wondering if there were any other options or any other cheaper OBDii devices that worked with clearing the error? Have read about Xtool VAG401 but wasn’t sure if it was compatible.
    Pacific Paradise QLD
    Quote Originally Posted by Tsizza View Post
    Hi guys,
    Ask dealer nicely to clear it Perfectly normal as I had a dash full when I got a flat battery. Took about 5 mins at the dealer and all good
    Erskineville, NSW
    Or ask on forum if somebody near you has VCDS
    Mar 2019
    Thanks. I live in Brisbane
    Jul 2018
    Hi Tsizza
    I have just hit the same problem - did you have any luck finding someone with a VCDS?
