Originally Posted by
Soundofav6
IF you can.. Fo it, really depends if the OEM head unit have RCA out put or if your Amp support speaker wire as input.
x2
questions you should ask yourself are ones such as whether you will be upgrading the rest of the system at a leter date, what sirt of power your current sub/amp combo has etc etc
if you arent planning to spend any more on the system in the future and your standard HU does not have the required RCA outputs you will have to get some line converters to convert the speaker outputs from your HU to RCA and then run your amps that way. although most amps these days have the inputs on them which allow direct conncetion of speaker outputs to the amplifier
this route generally leaves a big window of opportunity for losses in sound quality etc etc, so it may be worthwhile looking at upgrading your HU. a few entry units have multiple RCA out which makes things easier for you
also would have the advantage of giving you 'Sub Control' direct from the HU
just some thoughts
1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
