Originally Posted by
Pepe
Yep, put it in myself last weekend and this is correct. You carefully put the BT module into the foam "bracket", no screws, etc needed. In fact, when it's in the bracket and fitted, it'd actually not be touching the carpet/floor anyway, as the bracket is deeper than the unit itself. You need to be careful because it could snap if you force it in, but take your time, it only fits into it one way. There are velcro bits glued on to it, which hold the carpet fine. It fits very snuggled into it's position and you'd never know it was there.
Part number should be a page or two back in the thread, I posted it up about 2 weeks ago.
